@akohlmey Well, the previous compilation did use GPU via cuda, and I watched GPU usage by using nvidia-smi. I guess cuda was involved through pytorch in my previous compilation. I’ll try to reach out the supercomputer supporting team as you suggested. Thank you for pointing out the direction.
The issue has been resolved by my colleague. His solution is quoted as follows:
“the problem was with the runtime linker path (rpath) included in the lmp executable. and the solution is very simple: don’t use the version you’ve just built! first you have to run `make install’, puts the final version of lmp in $HOME/.local/bin”
