Hi all friends
I installed LAMMPS Windows parallel executable on a PC including 16 cores. but I do not know how can I run a simulation system involving all cores.
I write the following command in Terminal
lmp_windows<in
how should I identify the number of cores?
Thanks alot
Regards
Elena
Someone more famiiar with Windows should answer,
but I assume you also have MPI installed. So if that
includes the mpirun program, the normal way to do this
would be mpirun -np 16 lmp_windows < in
Or maybe there is a GUI you can bring up, type 16 into
a widget box, and click the Run button. That would
be a huge time saver ...
