Save coordinate of an atom AT A GIVEN TIME: how ?
I am making simulations of deposition.
For this I need to save the initial z coordinate of the deposited atom.
I have been using:
variable z_dep equal “z[v_id_deposited_now]”
So in the variable z_dep is the z coordinate of the additional atom.
The problem is that during the evolution this atoms change position and,
with it, the value of the variable z_dep.
But this is not what I need.
How can I save in memory the value of this coordinate AT THE BEGINNING, so that its value does not change with time ?
I need to access this value at a later stage.
Many thanks in advance for your help
Bests,
Daniele Scopece
PS: for completeness I have been using the fix
fix id_depositing all deposit {N_atoms_deposited} 1 {N_step_depositing} 1234567890 &
region reg_deposition global 1.0 1.5 vx 0.0 0.0 vy 0.0 0.0 vz -{proj_vel_Angpsec} -{proj_vel_Angpsec} &
units box
with variables defined above in the script.
The variable doc page has a section on how to
do this, near the bottom.
