I am trying to modify(increase/decrease) diameter of the particles within a run. and as suggested I am trying to use fix adapt. The fix works fine, but the scaling as suggested from the documentation doesnot seem to work.
I am reading in particle diameters from an input file and modifying the diameter while mentioning scale yes. but the output suggests that the diameter is modified according to the variable ramp only.
I am attaching input script here. Please suggest if I am doing anything wrong?
Kind regards
Prashant
IC13.in (919 Bytes)
in.lammps (663 Bytes)
