Dear users,
By running same script always I am getting same output. Is it the real case?
I thought that it should vary about an average value. Please clarify me.
Another thing, is it possible to save the values of a variable at every run in an output file?
Dear users,
yes. if you don't change anything and don't have a
source of true randomnes you should get the same
answer. you use a computer and if they don't produce
the same result when doing the same thing, a lot of
researchers would be in great trouble.
no. why??
Thank you Dr. Axel for your answer.
Actually I calculated thermal conductivity at every 2000 steps and also could save them in a file by “thermo_style” command .
But in that file there are other variables also. and because of that It is bit difficult to get the values of thermal conductivity to plot them as a function of time. So I just wanted to save them in a file which is containing nothing but only the values of thermal conductivity.and doing so it could have been convenient for me to plot.
Thanks & Regards
could save them in a file by "thermo_style" command .
try reading the LAMMPS manual.
you would discover things like fix print,
which might be just what you are looking for.
