The title says it all, the search function on the pymatgen github site doesn’t appear to work. I am not sure if this is a pymatgen problem or a github problem, but it is certainly inconvenient.
Interesting, thanks for the report. I suspect it’s not a GitHub problem but may be a Sphinx issue, which is the documentation builder we use. I’ll try and upgrade Sphinx and re-generate the docs to see if I can fix it.
Matt
Ok this is working for me now, hope it’s fixed for you as well!
Hi mkhorton,
The search functionality on https://pymatgen.org/ does not work again. Could you pls help fix it? It is inconvenient to check docs without it.
Thanks!
Zhenbin
