I’m trying to do a very basic simulation of 1 type of atom gas interacting with Mie (or Lennar Jones) potential in the NPT ensemble.
The purpose is to evaluate the second virial coefficient at different temperatures.
** 1. is there any automatic command to evalutate the compressibility factor or the virial coefficient directly from LAMMPS? **
I took the average of thermodynamic parameters P, T, and ρ from the simulation and then I evaluated the compressibility factor as
Z = P/(ρ*T) where P is the pressure, T is the temperature and ρ is the density
Then, by knowing that Z~1+Bρ, I evaluated B as (Z-1)/ρ
I repeated these steps for some simulation, by varying the temperature.
When I plot B as function of T I find an unexpected trend. In particular if I invert the the sign of B the trend is correct but negative.
** 2. does the procedure is right? **
