I would not use fix property/atom but rather atom_style hybrid sphere bond to introduce molecule IDs. That is a more commonly used path. Reading data for fixes from a data file is by construction rather fragile and I doubt that anybody has ever tested it with read_data_add.
There is another serious problem in your input. Have you noticed this line in the log file?
WARNING: One or more atoms are time integrated more than once (src/modify.cpp:292)
In most cases, this is an indication of a serious problem. The situations where it can be ignored are extremely rare (the fact they do exist is the reason that this is not an error).
@Dseo
I’ve dug a bit deeper into the code for reading data file sections from fix files and could identify and work around the bug that exists when using read_data add and causes a segmentation fault.
The following change (relative to the current development branch) should resolve it. I will be included in the next patch release of LAMMPS.
diff --git a/src/fix_property_atom.cpp b/src/fix_property_atom.cpp
index 24704a12ad..95e25c59b2 100644
--- a/src/fix_property_atom.cpp
+++ b/src/fix_property_atom.cpp
@@ -325,12 +325,12 @@ void FixPropertyAtom::read_data_section(char *keyword, int n, char *buf, tagint
- return # of lines in section of data file labeled by keyword
+ return # of lines in section of data file labeled by keyword. -1 signals use # of added atoms
bigint FixPropertyAtom::read_data_skip_lines(char * /*keyword*/)
- return atom->natoms;
+ return -1;
diff --git a/src/read_data.cpp b/src/read_data.cpp
index ee6399a2d3..5317a4217a 100644
--- a/src/read_data.cpp
+++ b/src/read_data.cpp
@@ -875,10 +875,13 @@ void ReadData::command(int narg, char **arg)
int i;
for (i = 0; i < nfix; i++)
if (strcmp(keyword, fix_section[i]) == 0) {
- if (firstpass)
+ if (firstpass) {
fix(fix_index[i], keyword);
- else
- skip_lines(fix_index[i]->read_data_skip_lines(keyword));
+ } else {
+ auto nskip = fix_index[i]->read_data_skip_lines(keyword);
+ if (nskip < 0) nskip = natoms;
+ skip_lines(nskip);
break;
if (i == nfix)
@@ -2225,6 +2228,7 @@ void ReadData::fix(Fix *ifix, char *keyword)
int nchunk, eof;
bigint nline = ifix->read_data_skip_lines(keyword);
+ if (nline < 0) nline = natoms;
bigint nread = 0;
while (nread < nline) {
