Dear LAMMPS developers and users,
I’m trying to build my system using multiple files read option in read_data command (LAMMPS, stable 12 Aug 2018). Firstly, system consisting of calcite and aqueous solution run with NVT ensemble and then another aqueous solution is added to the system;
package gpu 1 neigh yes newton off
suffix gpu
units real
atom_style full
bond_style harmonic
angle_style harmonic
improper_style cvff
pair_style lj/cut/coul/long 13.0 14.0
kspace_style pppm 1.0e-4
read_data F.data
pair_coeff 3 3 0 0 #H,H
pair_coeff 3 6 0 1.594 #H,O
pair_coeff 3 11 0.000006968 4.497 #H,aO3
pair_coeff 6 9 0.116079 3.47 #aC2,O
pair_coeff 6 10 0.269896 2.76 #aCa1,O
pair_coeff 6 11 0.14603 3.12 #O,O3
pair_coeff 9 9 2.65 2.62 #Ca2,aC2
pair_coeff 9 11 6.266 1.196 #aC2,aO3
pair_coeff 10 11 0.2388 2.805 3.435 #Ca1,aO3
pair_coeff 11 11 0.00027276 4.744 #aO3,aO3
pair_modify mix arithmetic
neighbor 2 bin
group Calcite type 9 10 11
group water type 3 6
group sulphate type 7 8
fix 1 Calcite setforce 0.0 0.0 0.0
minimize 1.0e-4 1.0e-6 10000 100000
velocity all create 348.0 12345678 dist uniform
velocity Calcite set 0 0 0 units box
fix 2 water shake 1e-4 500 0 b 1 a 1
fix 3 all nvt temp 348.0 348.0 100.0
thermo 10
thermo_style custom step temp press &
pe ke etotal enthalpy
timestep 1
dump 1 all xyz 10 dump1.xyz
dump_modify 1 sort id
reset_timestep 0
run 500
read_data I.data add append shift 0.0 0.0 60.0
unfix 3
fix 4 all nvt temp 348.0 348.0 100.0
dump 2 all xyz 10 dump2.xyz
dump_modify 2 sort id
run 500
when reading the second data file, I received the following error:
Reading data file …
orthogonal box = (-40.2788 -42.8653 -38.1737) to (41.4712 42.5147 110.506)
reading atoms …
6190 atoms
[System2:16456] *** Process received signal ***
[System2:16456] Signal: Segmentation fault (11)
[System2:16456] Signal code: Address not mapped (1)
[System2:16456] Failing at address: 0x561fe7248db0
[System2:16456] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890)[0x7f1573f1a890]
[System2:16456] [ 1] lmp_ss(+0x1c26bb)[0x5620c31a76bb]
[System2:16456] [ 2] lmp_ss(+0x964562)[0x5620c3949562]
[System2:16456] [ 3] lmp_ss(+0x969ee0)[0x5620c394eee0]
[System2:16456] [ 4] lmp_ss(+0x17531e)[0x5620c315a31e]
[System2:16456] [ 5] lmp_ss(+0x172821)[0x5620c3157821]
[System2:16456] [ 6] lmp_ss(+0x1732fa)[0x5620c31582fa]
[System2:16456] [ 7] lmp_ss(+0xbe368)[0x5620c30a3368]
[System2:16456] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7f1573b38b97]
[System2:16456] [ 9] lmp_ss(+0xc946a)[0x5620c30ae46a]
[System2:16456] *** End of error message ***
Segmentation fault (core dumped)
Due to limitation for size of attachment, I cannot send associating input and data files, however it will be OK to send anyone if want. It should be mentioned that the type of atoms, bond and angles are the same in both data files.
I would appreciate if anyone help me with this.
Thank you in advance
