Hi everybody,
I want to report an error with the polymorphic style in lammps (version 16. Feb. 2016).
Everytime i used the pair_style polymorphic a Segmentation fault appears (see end of the mail, for an example setup, but it occured with all used systems (same potential file, other configurations/systems)).
I checked my input file with old version of lammp(10Aug2015), and my lammps version with input files
without polymorphic potential. They worked all.
I can fix it by using the old pair_polymorphic.cpp/.h files in the new lammps version.
So i think/hope its not a fault on my inputfiles/system, (also recompiled my old lammpsversion (10Aug2015), to check if its not a problem of my libs).
I haven’t found that files in the changed files since 16.Feb.2016, so i wanted to report that issue.
Greetings,
Michael
Error message:
Replicating atoms …
triclinic box = (0 0 0) to (19.96 17.284 17.061) with tilt (-9.98 0 0)
192 atoms
[pccp7:07182] *** Process received signal ***
[pccp7:07182] Signal: Segmentation fault (11)
[pccp7:07182] Signal code: Address not mapped (1)
[pccp7:07182] Failing at address: (nil)
[pccp7:07182] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x10340) [0x7fefc8897340]
[pccp7:07182] [ 1] /lib/libc.so.6(+0x3d517) [0x7fefc4dd4517]
[pccp7:07182] [ 2] /home/micha/progs/lammps-16Feb16/src/lmp_ubuntu.1(_ZN9LAMMPS_NS15PairPolymorphic9read_fileEPc+0x2d8) [0x13f74c8]
[pccp7:07182] [ 3] /home/micha/progs/lammps-16Feb16/src/lmp_ubuntu.1(_ZN9LAMMPS_NS15PairPolymorphic5coeffEiPPc+0x22b) [0x13fc08b]
[pccp7:07182] [ 4] /home/micha/progs/lammps-16Feb16/src/lmp_ubuntu.1(_ZN9LAMMPS_NS17PairHybridOverlay5coeffEiPPc+0x19e) [0xeffdee]
[pccp7:07182] [ 5] /home/micha/progs/lammps-16Feb16/src/lmp_ubuntu.1(_ZN9LAMMPS_NS5Input15execute_commandEv+0xe9d) [0xb2ab1d]
[pccp7:07182] [ 6] /home/micha/progs/lammps-16Feb16/src/lmp_ubuntu.1(_ZN9LAMMPS_NS5Input4fileEv+0x31f) [0xb2af6f]
[pccp7:07182] [ 7] /home/micha/progs/lammps-16Feb16/src/lmp_ubuntu.1(main+0x46) [0x65dfc6]
[pccp7:07182] [ 8] /lib/libc.so.6(__libc_start_main+0xf5) [0x7fefc4db8ec5]
[pccp7:07182] [ 9] /home/micha/progs/lammps-16Feb16/src/lmp_ubuntu.1() [0x66f857]
[pccp7:07182] *** End of error message ***
Segmentation fault (core dumped)
