Serial LAMMPS with Python
To whom it may concern,
When using LAMMPS through Python there is an issue that occurs. If mpi4py is installed, there is no way to use a serial version of LAMMPS. I have an MWE below which does not work for me because I have mpi4py installed.
import lammps
lmp = lammps.lammps(‘serial’)
The error that I get is as follows:
[zapp:08231] *** Process received signal ***
[zapp:08231] Signal: Segmentation fault (11)
[zapp:08231] Signal code: Address not mapped (1)
[zapp:08231] Failing at address: 0x19
[zapp:08231] [ 0] /lib64/libpthread.so.0(+0x13030)[0x7fa0318d2030]
[zapp:08231] [ 1] /usr/lib64/openmpi/lib/libmpi.so.20(PMPI_Type_size+0x4b)[0x7fa02a3dbe2b]
[zapp:08231] [ 2] /global/lammps/builds/stable/lib/liblammps_serial.so(_ZN9LAMMPS_NS6LAMMPSC1EiPPci+0x383)[0x7fa023d94883]
[zapp:08231] [ 3] /global/lammps/builds/stable/lib/liblammps_serial.so(lammps_open_no_mpi+0x3f)[0x7fa023bcd90f]
[zapp:08231] [ 4] /lib64/libffi.so.6(ffi_call_unix64+0x4c)[0x7fa02a866ace]
[zapp:08231] [ 5] /lib64/libffi.so.6(ffi_call+0x35f)[0x7fa02a86648f]
[zapp:08231] [ 6] /usr/lib64/python3.7/lib-dynload/_ctypes.cpython-37m-x86_64-linux-gnu.so(_ctypes_callproc+0x601)[0x7fa02a7cef71]
[zapp:08231] [ 7] /usr/lib64/python3.7/lib-dynload/_ctypes.cpython-37m-x86_64-linux-gnu.so(+0x136ef)[0x7fa02a7cf6ef]
[zapp:08231] [ 8] /lib64/libpython3.7m.so.1.0(_PyObject_FastCallKeywords+0x4bd)[0x7fa031a5956d]
[zapp:08231] [ 9] /lib64/libpython3.7m.so.1.0(_PyEval_EvalFrameDefault+0x5b0e)[0x7fa031aaa07e]
[zapp:08231] [10] /lib64/libpython3.7m.so.1.0(_PyEval_EvalCodeWithName+0x2e8)[0x7fa0319f39b8]
[zapp:08231] [11] /lib64/libpython3.7m.so.1.0(_PyFunction_FastCallDict+0x2ed)[0x7fa0319f4b8d]
[zapp:08231] [12] /lib64/libpython3.7m.so.1.0(_PyObject_Call_Prepend+0x66)[0x7fa031a05136]
[zapp:08231] [13] /lib64/libpython3.7m.so.1.0(+0x171f71)[0x7fa031a52f71]
[zapp:08231] [14] /lib64/libpython3.7m.so.1.0(_PyObject_FastCallKeywords+0x116)[0x7fa031a591c6]
[zapp:08231] [15] /lib64/libpython3.7m.so.1.0(_PyEval_EvalFrameDefault+0x5b0e)[0x7fa031aaa07e]
[zapp:08231] [16] /lib64/libpython3.7m.so.1.0(_PyEval_EvalCodeWithName+0x2e8)[0x7fa0319f39b8]
[zapp:08231] [17] /lib64/libpython3.7m.so.1.0(PyEval_EvalCodeEx+0x43)[0x7fa0319f4873]
[zapp:08231] [18] /lib64/libpython3.7m.so.1.0(PyEval_EvalCode+0x1b)[0x7fa0319f489b]
[zapp:08231] [19] /lib64/libpython3.7m.so.1.0(+0x23a8c2)[0x7fa031b1b8c2]
[zapp:08231] [20] /lib64/libpython3.7m.so.1.0(+0xd928b)[0x7fa0319ba28b]
[zapp:08231] [21] /lib64/libpython3.7m.so.1.0(PyRun_InteractiveLoopFlags+0xeb)[0x7fa0319be106]
[zapp:08231] [22] /lib64/libpython3.7m.so.1.0(+0xdd1a3)[0x7fa0319be1a3]
[zapp:08231] [23] /lib64/libpython3.7m.so.1.0(+0x23f261)[0x7fa031b20261]
[zapp:08231] [24] /lib64/libpython3.7m.so.1.0(_Py_UnixMain+0x3c)[0x7fa031b2049c]
[zapp:08231] [25] /lib64/libc.so.6(__libc_start_main+0xf3)[0x7fa03158e413]
[zapp:08231] [26] python3(_start+0x2e)[0x55f98a07008e]
[zapp:08231] *** End of error message ***
zsh: segmentation fault (core dumped) python3
If I change ‘serial’ in the MWE above to ‘mpi’, everything works fine. I have not been able to find a fix for it and wanted to let you know of the issue.
Thank you,
Brandon Laufer
sorry, but i cannot confirm this. here is what i did:
make serial mode=shlib
make install-python
python
import mpi4py
import lammps
l = lammps.lammps()
LAMMPS (28 Feb 2019)
can you please tell us which LAMMPS version you are using?
and send us the output of:
ldd ./liblammps_serial.so
import lammps
this error i have only seen, when using a LAMMPS shared library that was compiled/linked against OpenMPI while the LD_LIBRARY_PATH was set up for MPICH or vice versa.
what happens, if you build an executable with:
make serial mode=shexe
then run ./lmp_serial and input:
info config communication
and send us the output.
thanks,
