Sorry. Here is the way to do it. I just tried it with in.lj script
variable grouplargeatoms
variable s file atomids.txt
group atoms id $s
group collect union atoms
next s
jump in.lj grouplargeatoms
After the loop the group collect will have all the atoms
Good luck
Arun Srikanth
Phd student
Drexel university
It seems that even without the line “group collect union atoms” it works.
group atoms id $s
next s
i don't think the union thing is necessary. group definitions are
incremental, so the atoms group should already have all desired atoms.
also i tried the atomfile variant and it works fine, too (for in.lj you
also need to request an atom map).
the atom file format has the number of ID value pairs as the first line and
then reads the corresponding list of entries. all entries that are not set
are initialized to zero. zero means false and non-zero means true. so you
can have a file like this:
10
1 1
2 0
3 1
4 0
5 1
6 1
7 1
9 1
11 1
20 1
and then simply do:
variable ids atomfile atomfile.txt
group atoms variable ids
and the group will contain the 8 atoms that are set to 1.
