I’m trying to set a time dependent dipole moment for a pair of particles by calculating a variable with:
- variable Field atom time*1e-9
and then I write:
- set group Atoms dipole 0 0 v_Field
The problem is that instead of assigning the value of the calculated variable to the z component of the dipole moment, it assigns zero. Even if I set the initial value to something other than zero, the set command will put it back to zero.
However if I dump the value of v_Field, it is being updated every loop. Also, if I substitute time for xlo, the calculated value is correctly set to the dipole moment. The same problem arises if I try to set the position to a time dependent variable.
I’m sending a working example.
Thanks in advance,
Antonio Ortiz.
----- LAMMPS Input File -----
units micro
atom_style hybrid sphere dipole bond
boundary s s p
neighbor 4.0 nsq
pair_style lj/cut/dipole/cut 20
read_data TimeDependentInput.data
group Atoms type 1
mass * 1
timestep 10000
variable thermoname equal time/1e9
dump 3 all custom 10 TimeDependentField.lammpstrj id type x y z v_Field muz
thermo_style custom step atoms v_thermoname
thermo 1000
run 6000
----- TimeDependentInput.data File -----
4 atoms
2 atom types
-30.00 30.00 xlo xhi
-30.00 30.00 ylo yhi
-1.50 1.50 zlo zhi
Atoms
1 2 15.00 0.00 0.000000 10.30 0.0017 0.0 0 0 0 1
2 2 -15.00 0.00 0.000000 10.30 0.0017 0.0 0 0 0 2
3 1 15.01 0.00 0.014681 10.30 0.001678 0.0 0.0 0.0 0.002 1
4 1 -15.01 0.00 0.016334 10.30 0.001678 0.0 0.0 0.0 0.002 2
PairIJ Coeffs
1 1 0.0 0.0 0.0 60.000000
1 2 0.0 0.0 0.0 0.0
2 2 0.0 0.0 0.0 0.0
