I forgot to add info about the error.
When I go into python and type the following I get the error below
from lammps import lammps
l=lammps()
File “”, line 1, in
File “/Users/daw/D_downloaded_software/D_LAMMPS/lammps-12Dec18/python/lammps.py”, line 94, in init
if not name: self.lib = CDLL(“liblammps.so”,RTLD_GLOBAL)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ctypes/init.py”, line 365, in init
self._handle = _dlopen(self._name, mode)
OSError: dlopen(liblammps.so, 10): image not found
I had defined these environment variables in .cshrc:
setenv DYLD_LIBRARY_PATH /usr/local/lib:/Users/daw/D_downloaded_software/D_LAMMPS/lammps-12Dec18/build_serial
setenv LD_LIBRARY_PATH /usr/local/lib:/Users/daw/D_downloaded_software/D_LAMMPS/lammps-12Dec18/build_serial
setenv PYTHONPATH /Users/daw/D_downloaded_software/D_LAMMPS/lammps-12Dec18/python
