My system includes some water(2226 water molecules(spc/e)),a membrane(4000 carbon atoms,no charge) consists of amorphous carbon and a graphite wall using for compressing water.After running several steps,it gives an error: Shake atoms missing.It is difficult for me to understand this problem because the shake output seems no problem.Another question is that it takes 14404s CPU(16-core parallel) time to run 6500 steps for my system;Why my MD speed so slow?How can I optimize my parameters in Lammps to speed up my calcation?
but using neigh_modify delay 10 is very aggressive.
hard to say without knowing more about your system,
e.g. the dimensions of your box, but there are two
likely reasons: load imbalance and using ewald instead
of pppm. also, with the processors 2 2 2 line, you
can only run with 8 MPI tasks. with proper updates
to the neighbor lists, you may be able to increase
the time step to 2fs.
cheers,
The error is b/c one or more atoms moved too far.
Re: speed - you are running Ewald which can
be very slow, esp for big systems. Try PPPM.
And try running on 1 proc for a short run and look
at the timing breakdown. That will tell you where
it is spending time and help you judge whether it is
faster on 16 procs,
