Thanks Steve,
Yes. The fix spring command can hold two group atoms at a certain distance. However, the distance may exist a large fluctuation near the fixed distance. What I want is that one can fix the distance and obtain the constraint force, f_c, at the fixed position, z, in order to calculate the local diffusion coefficient using the following equation:
D(z) = (K_B* T)^2/ ++<delta_fc(t)*delta_fc(0)> dt.
So, I do not want to the fixed distance with a large fluctuation. Is there other method that can be used to deal with this.
Thanks again.
Thanks Steve,
the magnitude of the fluctuations is determined by the force
constant of the spring.
i don't see any alternative unless you want to program this yourself.
I don't think most people do PMF calculations with the 2 bodies
held at a fixed distance, rather by a spring. It can be a stiff
spring if you like. Many people use LAMMPS to do PMF calculations
in that way. There is no fix in LAMMPS to enforce
a long distance contstraint such as you are asking, i.e. one that fixes
a bond that spans the size of the system.
