Dear lammps community,
I’m new to lammps and wanted to do some first calculations on Si clusters with oxygen on their surface.
I want to use the COMB potential for this, unfortunately the calculation stops after the first step with the segmentation fault error:
Step Temp E_pair E_mol TotEng Press
0 0 -238.48186 0 -238.48186 -109.78007
Segmentation fault
I let the Qeq equilibration info write to a file and I get
Charge equilibration on step 0
iteration: 0, enegtot 18.3786, enegmax 49.7514, fq deviation: 11.1742
iteration: 1, enegtot 18.0347, enegmax 43.6399, fq deviation: 9.8116
iteration: 2, enegtot 17.3506, enegmax 33.5105, fq deviation: 7.5594
iteration: 3, enegtot 16.394, enegmax 21.0967, fq deviation: 5.01134
iteration: 4, enegtot 15.6893, enegmax 9.76827, fq deviation: 2.48154
iteration: 5, enegtot 36.8182, enegmax 242.488, fq deviation: 38.6245
iteration: 6, enegtot 15.9529, enegmax 27.0752, fq deviation: 4.39309
iteration: 7, enegtot -6.93144, enegmax 2340.52, fq deviation: 48.1158
iteration: 8, enegtot 47845.8, enegmax 6.16675e+06, fq deviation: 94401.5
iteration: 9, enegtot -nan, enegmax nan, fq deviation: nan
iteration: 10, enegtot -nan, enegmax nan, fq deviation: nan
iteration: 11, enegtot -nan, enegmax nan, fq deviation: nan
I then came across a thread by K. McKenna ( Date: Wed, 20 Mar 2013 13:07:30 +0000) who faced similar problems, when adding oxygen to a Ti surface.
I therefore simplified my system and now I first want to simulate a pure Si cluster with 71 Si atoms in a quadratic box, but the calculation still stops as described above and I get the same segmentation fault error.
The charge equilibration looks fine now, though, so the oxygen is not causing the problem.
My input file looks like this:
atom_style charge
pair_style comb
newton on
read_data Si71_comb.data
pair_coeff * * …/…/potentials/ffield.comb Si
group Si type 1
timestep 0.001
thermo 50
thermo_modify format float %15.8g
dump 1 Si xyz 10 Si71_GEOMETRY.xyz
dump_modify 1 format “%s %15.15g %15.15g %15.15g” element Si
fix 1 Si nvt tchain 4 temp 0.0 1000.0 100
fix 2 Si qeq/comb 50 0.0001 file charge.out
run 500
unfix 1
fix 3 Si nvt tchain 4 temp 1000.0 1000.0 100
run 100
unfix 3
fix 4 Si nvt tchain 4 temp 1000.0 500.0 100
run 100
unfix 4
fix 5 Si nvt tchain 4 temp 500.0 0.0 100
run 100
unfix 5
unfix 2
minimize 1.0e-10 1.0e-14 1000 1000
undump 1
And the data file:
71 atoms
1 atom types
-25.00000 25.00000 xlo xhi
-25.00000 25.00000 ylo yhi
-25.00000 25.00000 zlo zhi
Masses
1 28.0855
Atoms
1 1 0.0000 -5.429356 -2.714678 -2.714000
2 1 0.0000 -5.429356 -2.714678 2.714000
3 1 0.0000 -5.429356 2.714678 -2.714000
4 1 0.0000 -5.429356 2.714678 2.714000
5 1 0.0000 5.429356 -2.714678 -2.714000
6 1 0.0000 5.429356 -2.714678 2.714000
7 1 0.0000 5.429356 2.714678 -2.714000
8 1 0.0000 5.429356 2.714678 2.714000
9 1 0.0000 -5.429356 0.000000 0.000000
10 1 0.0000 5.429356 0.000000 0.000000
11 1 0.0000 -4.072017 -4.072017 1.357000
12 1 0.0000 -4.072017 4.072017 -1.357000
13 1 0.0000 4.072017 -4.072017 -1.357000
14 1 0.0000 4.072017 4.072017 1.357000
15 1 0.0000 -4.072017 -1.357339 4.072000
16 1 0.0000 -4.072017 1.357339 -4.072000
17 1 0.0000 4.072017 -1.357339 -4.072000
18 1 0.0000 4.072017 1.357339 4.072000
19 1 0.0000 -4.072017 -1.357339 -1.357000
20 1 0.0000 -4.072017 1.357339 1.357000
21 1 0.0000 4.072017 -1.357339 1.357000
22 1 0.0000 4.072017 1.357339 -1.357000
23 1 0.0000 -2.714678 -5.429356 -2.714000
24 1 0.0000 -2.714678 -5.429356 2.714000
25 1 0.0000 -2.714678 5.429356 -2.714000
26 1 0.0000 -2.714678 5.429356 2.714000
27 1 0.0000 2.714678 -5.429356 -2.714000
28 1 0.0000 2.714678 -5.429356 2.714000
29 1 0.0000 2.714678 5.429356 -2.714000
30 1 0.0000 2.714678 5.429356 2.714000
31 1 0.0000 -2.714678 -2.714678 -5.429000
32 1 0.0000 -2.714678 -2.714678 5.429000
33 1 0.0000 -2.714678 2.714678 -5.429000
34 1 0.0000 -2.714678 2.714678 5.429000
35 1 0.0000 2.714678 -2.714678 -5.429000
36 1 0.0000 2.714678 -2.714678 5.429000
37 1 0.0000 2.714678 2.714678 -5.429000
38 1 0.0000 2.714678 2.714678 5.429000
39 1 0.0000 -2.714678 -2.714678 0.000000
40 1 0.0000 -2.714678 2.714678 0.000000
41 1 0.0000 2.714678 -2.714678 0.000000
42 1 0.0000 2.714678 2.714678 0.000000
43 1 0.0000 -2.714678 0.000000 -2.714000
44 1 0.0000 -2.714678 0.000000 2.714000
45 1 0.0000 2.714678 0.000000 -2.714000
46 1 0.0000 2.714678 0.000000 2.714000
47 1 0.0000 -1.357339 -4.072017 4.072000
48 1 0.0000 -1.357339 4.072017 -4.072000
49 1 0.0000 1.357339 -4.072017 -4.072000
50 1 0.0000 1.357339 4.072017 4.072000
51 1 0.0000 -1.357339 -4.072017 -1.357000
52 1 0.0000 -1.357339 4.072017 1.357000
53 1 0.0000 1.357339 -4.072017 1.357000
54 1 0.0000 1.357339 4.072017 -1.357000
55 1 0.0000 -1.357339 -1.357339 -4.072000
56 1 0.0000 -1.357339 1.357339 4.072000
57 1 0.0000 1.357339 -1.357339 4.072000
58 1 0.0000 1.357339 1.357339 -4.072000
59 1 0.0000 -1.357339 -1.357339 1.357000
60 1 0.0000 -1.357339 1.357339 -1.357000
61 1 0.0000 1.357339 -1.357339 -1.357000
62 1 0.0000 1.357339 1.357339 1.357000
63 1 0.0000 0.000000 -5.429356 0.000000
64 1 0.0000 0.000000 5.429356 0.000000
65 1 0.0000 0.000000 -2.714678 -2.714000
66 1 0.0000 0.000000 -2.714678 2.714000
67 1 0.0000 0.000000 2.714678 -2.714000
68 1 0.0000 0.000000 2.714678 2.714000
69 1 0.0000 0.000000 0.000000 -5.429000
70 1 0.0000 0.000000 0.000000 5.429000
71 1 0.0000 0.000000 0.000000 0.000000
I first want to set up a simple routine to see if the script works, but even this is not working for me and I don’t know where the error is.
I hope someone can help me with this.
Paul
