Hi Lammps users,
I want to use silicon weth meam potential, and I installed the meam library. I cannot find Si.meam, so should I use SiC.meam and use NULL ?? If thats right, how can I write it ? Thanks\Mohamed
Hi Lammps users,
Hi Mohamed,
No, don’t use SiC.meam — instead use Ni.meam or Cu.meam and the related example problems as models of how to set up a single-element simulation. Most of the relevant parameters come from the library.meam file, which you can also edit or replace.
Regards,
Greg
Greg Wagner
Manager, Thermal/Fluid Science and Engineering Department
Sandia National Laboratories, Livermore, CA
Tel: (925) 294-2180 Fax: (925) 294-3410
Email: gjwagne@…3…
