Simulate an Einstein solid
Dear all.
  I am trying to simulate an (classical) Einstein solid using fix spring/self. I can simulate a solid (e.g., Fe with EAM potential) and add the fix spring/self. However, if I want only the fix spring/self, the following error is happening:
ERROR: Atom sorting has bin size = 0.0 (../atom.cpp:1859)
Last command: run
I suppose the LAMMPS integrator (NVE) needs a pair style. If so, it will not possible to run only with the fix spring/self, will it?
Can this problem be circumvented?
With best regards,
Pedro Moreira
Associate Professor, UFSCar, Brazil
This is what pair_style zero was made for.
You can change bin size: http://lammps.sandia.gov/doc/atom_modify.html
Michal
Stefan.
  That is the answer which I was looking for.
  Pedro
Citando Stefan Paquay <[email protected]...>:
