Hello All,
I am working on simulation of water in CNT using LAMMPS. I have used very large number for number of run (20000000) and dt=1 femtosecond in my input file.
After visualization, I can see the water fills entire the CNT; however, the water doesn’t exit the tube even after passing long time. I have a couple of questions about my results:
1- I plotted the velocity and density/number along radial in z direction. For this purpose, the ave/spatial command was used as following:
fix 1 all ave/spatial 2 5000 10000 x center 2.0 vx vy vz density/number bound z 32.0 58.26 units box file vel1.profile
fix 11 all ave/spatial 2 5000 10000 x center 2.0 vx vy vz density/number bound z 0.0 80.0 units box file vel11.profile
fix 22 all ave/spatial 2 5000 10000 x center 2.0 vx vy vz density/number bound z 0.0 11.47 units box file vel22.profile
fix 3 all ave/spatial 2 5000 10000 x center 2.0 vx vy vz density/number bound z 11.47 32.0 units box filevel3. profile
fix 44 all ave/spatial 2 5000 10000 x center 2.0 vx vy vz density/number bound z 58.26 80.0 units box file vel4.profile
fix 2 all ave/spatial 2 5000 10000 x center 2.0 vx vy vz density/number units box file vel2.profile
I used bounds z in this command to calculate the velocity in different sections of CNT. However, the velocity profiles are the same for all of profiles and I think my obtained results are based on the whole computational domain (bounds z command doesn’t work?). How can I get accurate velocity distribution in different sections of CNT in radial direction?
2- I am thinking that velocity profile after long time should get positive steady state values in CNT as I have read in the literature. However, the velocity is always changing each Nfreq (The time step which is used to calculate velocity). How can I approach this problem?
I attached the velocity and Density/number for different number of water molecules, lengths and radii of CNT after passing long time.
I really appreciate your help.
Hamed.
Results.pdf (399 KB)
