single function for specific pair style
Hi all,
Recently I’m trying to implement a new pair style in LAMMPS. I want to include this pair style in compute group/group. I searched in the mail lists of LAMMPS and knew that I need to write a routine named single() in my own pair style. I looked the codes of pair_lj_cut.cpp and several other pair styles, the structure for these single routines are the same:
single(int i, int j, int itype, int jtype, double rsq, double factor_coul, double,factor_lj,double &fforce).
But my pair style is a little bit more complicated because the potential is direction dependent, the potential form is E(x,y,z) instead of E®. So to calculate the energy, the structure of single function for my potential should be like follows:
single(int i, int j, int itype, int jtype, double delx, double dely, double delz, double factor_coul, double,factor_lj,double &fforce)
My question is, can I write the single function as above or it won’t work since I changed the structure of it?
Does anyone have any idea about this question? Thank you in advance!
Huang
Hi all,
Recently I'm trying to implement a new pair style in LAMMPS. I want to
is direction dependent, the potential form is E(x,y,z) instead of E(r). So
*double delx, double dely, double delz*, double factor_coul,
My question is, can I write the single function as above or it won't work
​it won't work.​
Hi Axel,
I see. Thanks!
Huang
BTW: there is an alternative to using compute group/group and those are the computes in the USER-TALLY package.
…and compute group/group won’t work for many-body potentials regardless, so if you would have based your pair style on airebo, you’d have been at a dead end from the beginning.
