Dear All,
I am trying to simulate a polymer system with 1000 chains (each with 40 monomers). To avoid blowing up of energy, I am using the methods like soft/fast push off (ref: Auhl-Plimpton, equilibration of long chain polymer melts in computer simulations) using LAMMPS. I found that pair style soft performs fast push off. I also found fix nve/limit as an alternate method for push off. But I have a doubt as to whether it really corresponds to slow push off? The reason is, from reading documentation it said the following
A limit is imposed on the maximum distance an atom can move in one timestep. Forces on atoms must still be computable (which typically means 2 atoms must have a separation distance > 0.0). But large velocities generated by large forces are reset to a value that corresponds to a displacement of length xmax in a single timestep. Xmax is specified in distance units; see the units command for details.
But in the paper, it is given by U® = (r-r_fc)*U’(r_fc) + U® for r< rfc and rfc is reduced from 2^1/6 sigma to 0.8 sigma. If xmax in LAMMPS equal r-r_fc, then is the reduction in rfc as told in the paper, automatically taken care of in the source code? Also if the velocities are scaled by a value corresponding to xmax, how exactly is the U® term (which is dependent on r and not a constant) incorporated?
Sorry for the big mail.
Thanks and Kind Regards
Vaidyanathan M S
Dept of Chemical Engg
UT Austin
