Sorry for such a simple question, but I am having trouble in simulating the decomposition/combustion/explosion of some materials, starting in solid state.
The structure of the crystal/molecules is totally changed in the first iteraction.
I am using ReaxFF and building the data file using VMD, after creating the molecule file using avogadro and then creating the crystal structure using packmol (basically I used the crystal lattice parameters and inserted a certain amount of molecules to achieve the near-experimental density). Maybe packmol is creating a high energy distribution?
I even tried to use the fix rigid command, but it keeps the material from decomposing over time.
Thanks for any suggestions.
state.
iteraction.
if your system has a high potential energy, you should see it in your
thermodynamic output.
if that is high, you could run a minimization (as it standard
procedure in MD) as initial part of your equilibration.
another common beginner's mistake with reaxff, is to generate a data
file with bonds/angles/dihedrals etc. those are computed dynamically
and providing them explicitly is an error, as it will change the force
field interactions.
finally, you have to carefully check the force field parameters. you
need a set that is specifically parameterized for your kind of system.
reaxff is very specific and the resulting parameter sets are not very
transferable.
