Some errors with comb3 calculation
Thank you all!
I have solved this problem and the code is running well now. I have a suggestion about this situation that when we use comb3 potential to calculate we should always be careful with the “fix qeq/comb” command. For example where should we insert this command line in script or how to set the parameters in this command line.
I just add this command line in the wrong position in my script and the calculation can`t go on. Also 1e-3 is the precision we usually use. Be careful to it.
I hope it will help
Ximeng
