Recently,When I try to add DPD-MESO pakage according to lammps manual.
cd /home1/xuehan/lammps-29Sep2021/src/DPD-MESO
make yes -DPD_MESO
As shown in figure:
but When I try to run in.test, it doesn’t work.Do you why?
make yes -DPD_MESO
As shown in figure:
This is not correct. there is an extra blank and that causes the error message you see because “make” sees two arguments “yes” and “-DPD_MESO” and the latter is responsible for the errors since there are no ‘-D’, ‘-P’, ‘-_’, ‘-M’, ‘-E’, or ‘-O’ options to the make command.
Please also note that “make yes-dpd_meso” is not sufficient to include the DPD_MESO package into your executable, you also need to recompile LAMMPS.
Before I add DPD-MESO pakage, I have compiled lammps.The following command was used
make yes-all
make no-lib
Just now,in src folder,I use the following command,it shows that DPD has been installed
but it didn’t work. I still cann’t use MDPD
Do I need to recompile lammps?
Thank you
Please re-read my previous reply.
I have solved the problem. Thank you
