if the results is different when i run the simulation under the serial and parallel environments , and the result under the parallel environment(use 16 cores) is wrong, what is the most possible problem?
the biggest possible problem _right now_ is, that your question is far
too vague and lacking any kinds of meaningful detail to give a useful
answer.
http://lammps.sandia.gov/guidelines.html
