I can’t set fireworks to start tasks with low id before the execution of task just added to the databases. I set to my_launchpad file SORT_FWS: “FIFO” , but i doesn’t change nothing. Someone have an idea of how to configure fireworks in that way?
Thanks in advance for help
Regards
Hi Laurenza
The SORT_FWS key will sort the Fireworks with state=“READY” by the “created_on” date. i.e., the next Firework to run should be one that is READY and that has the earliest “created_on” date.
Before running the launch command, perhaps try the following command:
lpad get_fws -s READY --sort created_on -m 1 -d all
That should give you all the details about the next Firework that will run in FIFO mode. A few notes:
If a Firework is not READY, it will not run. e.g. if it is waiting for a dependency to finish or is DEFUSED, etc.
The sorting is by created_on, not fw_id
Anubhav
Regards
