Hi everyone,
I’m trying to create an input.xml file for bulk MoS2 in the 2H crystal phase however I’m having trouble with creating the unit cell for a calculation. I think I’m using the spacegroup command wrong. I tried using spacegroup to create the input.xml file with the following spacegroup.xml file:
<?xml version="1.0" encoding="UTF-8" ?> <symmetries HermannMauguinSymbol="P63/mmc">
<title>2HMoS2</title>
<lattice a="5.9733279640198" b="5.9733279640198" c="23.23406024415133" ab="90"
ac="90" bc="120" ncell="1 1 1" />
<WyckoffPositions>
<wspecies speciesfile="Mo.xml">
<wpos coord="0.3333 0.6666 0.25 " />
</wspecies>
<wspecies speciesfile="S.xml">
<wpos coord=" 0.3333 0.6666 0.6275" />
</wspecies>
</WyckoffPositions>
</symmetries>
I then use the command spacegroup spacegroup.xml, however I do not get a geometry.xml file to use as input.xml. If I just type in spacegroup then I am asked for the different lattice parameters and atoms etc, however the amount of atoms that I need to write down does not match the actual amount of atoms found in the unit cell of MoS2.
Any help would be highly appreciated and thanks in advance,
Louis
