Let’s say I have two molecules A and B in my system. I need to turn off coulombic interaction between atoms of molecule A, but keep the coulombic interaction on between atoms of molecule B. Is there any way to achieve this?
I know how to use special_bonds command, but unfortunately it turns interactions off for ALL molecules.
Thank you for your help,
Ali
There is also a neigh_modify excluded molecule/intra command,
but that would turn off both LJ and Coulombic interactions
within molecules. Not sure if that is what you want.
If you use pair_modify pair you can set special_bond values
for LJ and Coulombic for sub-styles of a pair hybrid command.
So if you chose distinct atom types for your 2 molecules you
could assign them each sub-style(s) of a pair hybrid command
and control the intra-molecule interactions within each
molecule that way.
