Thanks Dr. Axel. I am not using the atype and dtype keywords in the fix bond/create (Lammps aug15 version) presently, so I do not have to allocate space for angles and dihedrals.
I allocated space for new bonds that are to be formed in the header file and also used the extra keyword when I use the special_bonds command which I have mentioned previously. The implementation is given below,
special_bonds lj/coul 0 1 1 extra 2
fix 2 crosslink bond/create 1 1 9 13 2 prob 0.5 85784 iparam 1 1 jparam 2 9
and in the input script I added the line
2 extra special per atom
I get the same error when I run the input script.
“ERROR on proc 0: Special list size. exceeded in fix bond/create (…/fix_bond_create.cpp:761)”.
Is this implementation of the fix bond/create correct ?
Also, it is not clear what is the value that should follow the extra keyword in the special_bonds command.
special_bonds lj/coul 0 1 1 extra ?
Does this value (N= 1-2 1-3 1-4 interactions to save space for) denote per atom value.
I have also tried changing the value that follows the extra keyword (3,4…). No use.
Any suggestions to clarify this issue would be helpful.
Arun
"ERROR on proc 0: Special list size. exceeded in fix bond/create
(../fix_bond_create.cpp:761)".
atom value.
yes, and it would require all topological 1-2, 1-3 and 1-4 pairs. even
if they are not excluded later.
this topic was just mentioned in another thread on the mailing list
today and the documentation will be updated
(3,4....). No use.
you may need a much larger number. try 24 or 32.
