Hi Users,
When setting up the bonds in the read_data, I noticed a bond is only specified once, for example:
bonds
1 3 1 7
2 2 1 3
3 1 1 2
4 4 2 5
5 4 2 6
6 4 2 4
In this case bond 3 between atom 1 and atom 2 is only specified once…you do not see:
bonds
1 3 1 7
2 2 1 3
3 1 1 2
4 1 2 1
5 4 2 5
6 4 2 6
7 4 2 4
I understand that you you really only need to name the bond once but is it OK to name the bond twice as in the second case?
Joe
Hi Users,
bonds
1 3 1 7
2 2 1 3
3 1 1 2
4 4 2 5
5 4 2 6
6 4 2 4
In this case bond 3 between atom 1 and atom 2 is only specified once...you
do not see:
bonds
1 3 1 7
2 2 1 3
3 1 1 2
4 1 2 1
5 4 2 5
6 4 2 6
7 4 2 4
why don't you just make an experiment
and see, if it makes a difference?
i have not looked at the code, but i would
expect it does. i would expect that the
interaction will be calculated twice.
cheers,
no, it is not. That would make 2 bonds between those atoms, which
you likely do not want.
