Hi dear users,
I use sphere atom style and I want to make a data file to generate my initial coordinates, in manual there is a clumn that specifies the density of each particle that is (mass/distance^3 units), what is distance in this formula? is this diameter or dictance between atoms or something else?
It is just telling you that the value is density which is mass/volume.
The distance (or volume units) are in whatever unit system
you are using, e.g. Angstroms^3. See the units command.
