Hello Everyone,
I want to apply a load for a specific time and then remove it. This is the variable that I have defined. To avoid numerical issues I have two questions.
variable oscillate equal -0.001*((-0.5*((exp(20.03(step-50))-1)/(exp(20.03(step-50))+1)))+0.5)
- Is there any step function in lammps that I can use instead of using this exp() math function?
- How can I use time in PS instead of using step?
Regards,
Hamed
Hello Everyone,
you can use any kind of comparison. it will evaluate to 1.0 if true and 0.0 if false.
you have access to all thermo keywords in variable expressions.
