Hi All,
I am using the Stillinger-Weber three body potential for modelling a system of patchy particles. I am in the testing and
parameterising phase at this point and am trying to move into running simulations on our GPU cluster.
Below are the .in, .dat as well as the quote of the command line input. As you can see, everything is identical except for the necessary changes (newton on [CPU] and newton off [GPU]). NOTE these are test simulations on one set of the building blocks so that I can see what the angular potential is doing - in the future, the simulations will be much larger than that. (the depth of the SW potential is purposefully set very deep so I can analyse the angular dependancy).
""" .in file for both
# initialisation
#newton on
units lj # decide
# atom-ID molecule-ID atom-type x y z
atom_style molecular
# bring in configuration
read_data init_fin.dat
# potentials
pair_style sw
pair_coeff * * sa.sw A B C D
pair_modify shift yes
# settings
neighbor 2.0 bin
neigh_modify delay 10 check no
group metal type 1 2
group linker type 3 4
thermo 1000
dump atomdump all custom 1 atom.dump id type mol x y z
fix one all rigid/nve/small molecule
fix langDyn all langevin 1.0 1.0 1.0 524361 zero no
# run
timestep 0.003
run 100000 # equilibration
""" .dat for both
LAMMPS data file. CGCMM style. atom_style full generated by VMD/TopoTools v1.5 on Thu Sep 03 14:48:08 ACST 2015
41 atoms
0 bonds
0 angles
0 dihedrals
0 impropers
4 atom types
0 bond types
0 angle types
0 dihedral types
0 improper types
-5.500000 11.500000 xlo xhi
-6.631000 10.369000 ylo yhi
-8.500000 8.500000 zlo zhi
Masses
1 1.000000 # A
2 4.090000 # B
3 1.000000 # C
4 2.750000 # D
Atoms
1 1 1 0 0 0 # A
2 1 2 0.585 -0.585 -0.585 # B
3 1 2 -0.585 0.585 -0.585 # B
4 1 2 -0.585 -0.585 0.585 # B
5 1 2 0.585 0.585 0.585 # B
6 2 1 2 0 0 # A
7 2 2 2.585 -0.585 -0.585 # B
8 2 2 1.415 0.585 -0.585 # B
9 2 2 1.415 -0.585 0.585 # B
10 2 2 2.585 0.585 0.585 # B
11 3 1 4 0 0 # A
12 3 2 4.585 -0.585 -0.585 # B
13 3 2 3.415 0.585 -0.585 # B
14 3 2 3.415 -0.585 0.585 # B
15 3 2 4.585 0.585 0.585 # B
16 4 1 6 0 0 # A
17 4 2 6.585 -0.585 -0.585 # B
18 4 2 5.415 0.585 -0.585 # B
19 4 2 5.415 -0.585 0.585 # B
20 4 2 6.585 0.585 0.585 # B
21 5 3 0 3.146 1.799 # C
22 5 3 0 4.354 1.799 # C
23 5 4 0 3.75 0.899 # D
24 5 4 0 3.75 0 # D
25 5 4 0 3.75 -0.899 # D
26 5 3 0 4.354 -1.799 # C
27 5 3 0 3.146 -1.799 # C
28 6 3 2 3.146 1.799 # C
29 6 3 2 4.354 1.799 # C
30 6 4 2 3.75 0.899 # D
31 6 4 2 3.75 0 # D
32 6 4 2 3.75 -0.899 # D
33 6 3 2 4.354 -1.799 # C
34 6 3 2 3.146 -1.799 # C
35 7 3 4 3.146 1.799 # C
36 7 3 4 4.354 1.799 # C
37 7 4 4 3.75 0.899 # D
38 7 4 4 3.75 0 # D
39 7 4 4 3.75 -0.899 # D
40 7 3 4 4.354 -1.799 # C
41 7 3 4 3.146 -1.799 # C
"""cmd line input
CPU : lmp_openmpi-gpu-spdp-gnu -echo log -in sa.in -log sa.log
GPU : lmp_openmpi-gpu-spdp-gnu -echo log -in sa.in -log sa.log -sf gpu -pk gpu 1
Now we have the .log files for both the CPU and GPU simulations. As you can see there is a significant difference in the initial potential value as well as simulation result. FOR the CPU case, the simulation goes to completion and does as you would expect, irreverisble binding at particular angles. FOR the GPU case and in the latest lammps version (3Sep2015) the simulation blows up and in the version I was previously using (CHECK THIS!!!!!!!) the simulation just "jiggles" in response to the langevin fix, implying the attractive part of the SW potential isn't having an effect.
""" CPU output
LAMMPS (29 Aug 2015)
# initialisation
#newton on
units lj # decide
orthogonal box = (-5.5 -6.631 -8.5) to (11.5 10.369 8.5)
reading atoms ...
41 atoms
0 = max # of 1-2 neighbors
0 = max # of 1-3 neighbors
0 = max # of 1-4 neighbors
1 = max # of special neighbors
# potentials
pair_style sw
Reading potential file sa.sw with DATE: 2015-08-20
# settings
neighbor 2.0 bin
20 atoms in group metal
21 atoms in group linker
thermo 1000
7 rigid bodies with 41 atoms
1.89769 = max distance from body owner to body atom
# run
timestep 0.003
Neighbor list info ...
1 neighbor list requests
update every 1 steps, delay 10 steps, check no
master list distance cutoff = 5.036
ghost atom cutoff = 5.036
binsize = 2.518 -> bins = 7 7 7
Memory usage per processor = 11.2005 Mbytes
Step Temp E_pair E_mol TotEng Press
0 0 1.2308816 0 1.2308816 0
1000 2.7110716 -9.1944283 0 -7.9050162 0.019694268
2000 1.5107948 -9.7073514 0 -8.9888026 -0.0079306458
3000 0.93520057 -9.8241235 0 -9.379333 0.0053456104
4000 1.0906908 -9.847369 0 -9.3286259 0.0050080574
5000 1.1364157 -9.8208016 0 -9.2803112 -0.009174185
6000 1.3357255 -9.6815657 0 -9.0462816 -0.037774577
7000 1.2984942 -9.8520559 0 -9.2344794 -0.0069013174
8000 2.3045147 -15.030861 0 -13.934811 -0.020193718
9000 1.2221497 -15.372095 0 -14.790829 -0.00058408825
10000 1.0616485 -15.407475 0 -14.902545 0.020892659
11000 0.91087958 -15.40347 0 -14.970247 -0.00073592008
12000 1.6335144 -18.698822 0 -17.921906 -0.022794724
13000 1.2813069 -18.971443 0 -18.362041 -0.021521265
14000 1.1485899 -18.838424 0 -18.292143 -0.03694827
15000 2.4514733 -20.440516 0 -19.274572 -0.11190808
16000 1.0575377 -22.54894 0 -22.045964 -0.014397182
17000 1.3349861 -22.523331 0 -21.888398 0.024794428
18000 0.91207475 -22.644379 0 -22.210588 -0.04056296
19000 1.832487 -22.571856 0 -21.700307 0.011538614
20000 1.4002912 -22.54827 0 -21.882277 -0.0277438
21000 0.8506624 -22.731448 0 -22.326864 -0.045125086
22000 1.3143871 -22.735235 0 -22.110099 -0.00080099796
23000 1.2311549 -22.596875 0 -22.011326 -0.075441219
24000 0.78124613 -22.562906 0 -22.191338 0.058578892
25000 1.4917853 -22.66575 0 -21.956242 -0.02474423
26000 0.94004427 -22.553644 0 -22.10655 0.02413593
27000 1.2680626 -22.768888 0 -22.165785 0.0043430591
28000 0.97811915 -22.55631 0 -22.091107 0.037683225
29000 1.0014401 -22.652356 0 -22.176061 0.0079897236
30000 1.2237054 -22.772006 0 -22.19 -0.0016892709
31000 0.98949037 -22.513278 0 -22.042667 0.0083929002
32000 1.1603494 -22.565838 0 -22.013964 0.039555464
33000 1.1909887 -22.671503 0 -22.105057 -0.069068652
34000 0.83236851 -22.555312 0 -22.159429 -0.037126642
35000 0.95772698 -22.528168 0 -22.072664 -0.045770645
36000 1.2307973 -22.708279 0 -22.1229 -0.065491668
37000 1.1142684 -22.556924 0 -22.026967 0.068989535
38000 1.4083013 -22.627103 0 -21.957301 -0.051103109
39000 1.2199974 -22.659522 0 -22.079279 -0.031532029
40000 1.3242981 -22.62046 0 -21.990611 0.050069896
41000 1.1811206 -22.739511 0 -22.177758 0.00042972183
42000 1.0818674 -22.632171 0 -22.117625 0.0075090237
43000 1.2629219 -22.661793 0 -22.061135 0.0039792648
44000 1.168607 -22.681943 0 -22.126142 0.032521217
45000 0.72499782 -22.688676 0 -22.34386 -0.028954744
46000 0.88785853 -22.535306 0 -22.113032 0.0019003569
47000 1.0699038 -22.53418 0 -22.025323 0.03273213
48000 1.1452294 -22.539984 0 -21.995302 -0.023980004
49000 1.1078029 -22.398678 0 -21.871796 0.017362745
50000 1.0468605 -22.768557 0 -22.27066 -0.040559963
51000 1.0407185 -22.520526 0 -22.02555 0.060690501
52000 1.0158089 -22.740736 0 -22.257607 0.086715631
53000 1.061659 -22.63546 0 -22.130525 0.012645193
54000 1.0732175 -22.581552 0 -22.071119 0.021369808
55000 1.3905587 -22.643967 0 -21.982604 0.048490814
56000 0.94634984 -22.704445 0 -22.254352 0.038778481
57000 0.86492862 -22.485103 0 -22.073735 0.0014345469
58000 1.1885398 -22.66684 0 -22.101559 -0.02201256
59000 1.2958178 -22.505558 0 -21.889255 0.021320442
60000 1.0494893 -22.587211 0 -22.088063 -0.022174458
61000 0.98685257 -22.60712 0 -22.137763 0.052859268
62000 1.0772396 -22.593076 0 -22.080731 -0.052302949
63000 1.0437253 -22.500267 0 -22.003861 0.045211045
64000 1.1681153 -22.695318 0 -22.139751 -0.049976988
65000 1.2885053 -22.593497 0 -21.980671 -0.035556036
66000 1.5847052 -22.574424 0 -21.820723 0.020778513
67000 0.94974968 -22.53164 0 -22.079929 -0.079755295
68000 1.034079 -22.619378 0 -22.12756 -0.000618855
69000 0.97753529 -22.610508 0 -22.145582 0.0081138557
70000 0.82709299 -22.689392 0 -22.296019 0.0081910325
71000 1.3223447 -22.520436 0 -21.891516 -0.0066960626
72000 0.70970299 -22.435553 0 -22.098012 0.010927805
73000 1.3394805 -22.408581 0 -21.771511 0.036480665
74000 0.91131107 -22.594459 0 -22.161031 -0.08331835
75000 1.2914389 -22.589922 0 -21.975702 0.12014528
76000 0.88205743 -22.708161 0 -22.288646 -0.068566226
77000 1.208503 -22.702439 0 -22.127664 0.011461871
78000 1.0175151 -22.595499 0 -22.111559 0.0073326127
79000 1.037866 -22.660008 0 -22.166389 -0.0048219405
80000 1.1918024 -22.512547 0 -21.945714 -0.0047141458
81000 1.3607701 -22.556817 0 -21.909621 -0.051729727
82000 1.0419028 -22.632963 0 -22.137424 0.001864072
83000 1.0407532 -22.66302 0 -22.168028 -0.026713677
84000 0.69315048 -22.534816 0 -22.205146 -0.0027664682
85000 0.84141467 -22.567906 0 -22.167721 0.065548789
86000 1.2987284 -22.660888 0 -22.0432 0.039629959
87000 1.1257664 -22.738975 0 -22.203549 0.010828917
88000 1.1892293 -22.493503 0 -21.927894 0.026608831
89000 1.9248536 -27.980886 0 -27.065407 0.12840739
90000 1.1487442 -28.105782 0 -27.559428 -0.005945451
91000 1.2732826 -28.202637 0 -27.597052 0.015001538
92000 1.3169628 -28.253376 0 -27.627016 -0.044282212
93000 0.67037506 -28.188683 0 -27.869846 0.022696448
94000 0.93366065 -28.123442 0 -27.679384 -0.05507667
95000 1.2242134 -28.141497 0 -27.559249 -0.0056333751
96000 3.4616147 -32.534006 0 -30.887628 -0.05682235
97000 0.815488 -33.683875 0 -33.296021 0.025283309
98000 1.0503114 -33.74562 0 -33.246081 -0.048108566
99000 1.6513703 -33.608152 0 -32.822744 -0.0033353658
100000 1.2193483 -33.671699 0 -33.091765 0.012517318
Loop time of 11.0311 on 1 procs for 100000 steps with 41 atoms
Performance: 2349714.590 tau/day, 9065.257 timesteps/s
98.2% CPU use with 1 MPI tasks x no OpenMP threads
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
