stoddardd Ford potential
Hi Dear all
I want to use the Stoddard Ford potential in my simulation.The formula for this potential function is given in the attachment.
Should this command “pair_style lj/sf cutoff” be used for this potential function ?
thanks
[Stoddard ford potential.docx|attachment](upload://yZvFtnDlzmF1SOSPDsnZEN90xZ0.docx) (18.7 KB)
Hi Dear all
Should this command "pair_style lj/sf cutoff" be used for this potential
function ?
​no, please compare to: ​
​axel.​
Isn’t this exactly the same as lj/smooth/linear (lammps.sandia.gov/doc/pair_lj_smooth_linear.html)?
Maybe for ease of maintenance we should get rid of one, and to not break backward comptability, just “alias” the other with a PairStyle macro? I can file a pull request if you want.
Isn't this exactly the same as lj/smooth/linear (
​yup. a few things are computed in a slightly different order, but i
compared some pair_write output for multiple parameter sets and it produced
identical forces and energies.​ funny how people in MD are bound to
re-invent the same basic wheels at least once every decade...
backward comptability, just "alias" the other with a PairStyle macro? I can
​no need to. i'll do it myself. i'll also merge the docs and related.​
thanks for noticing,
