Strange observation when changing Langevin to Nosé–Hoover
For simulating a polymer-graphene system in aqueous solution, I’m using NVE+Langevin thermostat for equilibrium (state 1) and then NPT for equilibrium and production runs (state 2).
However, at the time the ensemble is altered from state 1 to 2, the whole system starts to move badly, esp. in y and z directions (and coming from other sides due to pbc). I have attached a short video from the simulation (about 5 ns), and this bad behavior happens after about 1 s of the video (solvent is not shown).
I appreciate if you take a look at this. I didn’t notice this behavior when I used NPT only or Berendsen instead of Langevin.
The input file is as follows:
#LAMMPS 9 Dec 2014
PVC
units real
atom_style full
bond_style class2
angle_style class2
dihedral_style class2
improper_style class2
pair_style soft 12
pair_style lj/class2/coul/long 12
pair_modify tail yes table 12
newton on
read_data PVC.data
group all type 1 2 3 4 5 6 7 8 9 10 11
group Pchain type 2 3 4 5 6 7 8 9
group P_G type 1 2 3 4 5 6 7 8 9
group G type 1
group water type 10 11
kspace_style ewald 1e-4
special_bonds dreiding
neighbor 1 bin
neigh_modify delay 0 every 1 check yes page 1000000
comm_modify mode single cutoff 12 vel no
thermo 100
thermo_style custom step temp press vol density etotal ke pe enthalpy evdwl ecoul epair ebond eangle edihed eimp emol elong etail time
restart 2000 restart-min.*
minimize 1.0e-06 1.0e-06 100000 100000
velocity all create 290 123469 units box
reset_timestep 0
fix sh all shake 0.000001 1000 0 t 10 11 b 14 a 29
####state 1###
fix Eq1 all nve
fix Eq11 all langevin 290 290 100 481579
dump Eq1112 all custom 10000 dump-total.lammpstrj id mol type element mass q x y z xs ys zs
compute comP01 Pchain com
fix comP01 Pchain ave/time 5 99 500 c_comP01[1] c_comP01[2] c_comP01[3] file tmp.comP01
thermo 500
thermo_modify lost warn flush yes
timestep 0.00005
restart 100000 restart-eq1.*
run 100000
thermo 500
timestep 0.0001
run 100000
thermo 500
timestep 0.0005
run 100000
thermo 500
timestep 0.001
run 100000
thermo 500
timestep 0.005
run 100000
thermo 500
timestep 0.01
run 100000
thermo 500
timestep 0.05
run 100000
thermo 500
timestep 0.1
run 100000
thermo 500
timestep 0.5
run 200000
thermo 500
timestep 1
run 2000000
unfix Eq1
unfix Eq11
####state 2###
fix Eq2 all npt temp 290 290 500 iso 1 1 5000
thermo 500
timestep 1
run 5000000
unfix sh
unfix Eq2
write_data data.end
write_restart restart.end
Langevin.wmv (2.12 MB)
Langevin can introduce a random drift velocity
to the system, unless you run it with the zero yes
option. You could also use the velocity command
between the runs to zero any net momentum.
