Hello
I found a strange result from my species.out.
I used species.out as
fix species all reax/c/species 1 1 400 species.out element Si O H H H O O O Si
(Reason why I used lots of element is because I masked some atoms)
and inside the species.out file, I found lines such as
Timestep No_Moles No_Specs Si430H48O260Si146 O H2O H O243H24O914Si124Si451 HO Si H O H2O HO H
3814 117 12 1 1 1 3 1 1 1 1 1 94 6 6
As you can see. H2O appears twice in here. I tried with
fix species all reax/c/species 1 1 400 species.out element H O Si
(without any masking geometry) But the same thing happened in species.out
Is this normal? How can I escape from this situation?
Also, is the mol_fra.c result same with species.out?
I found the mol_fra.c reads connection table. Is the mol_fra.c use updated bond order from connection table for each frame? Or it use fixed bond order given in Cutoff.dic?
Joon
Hello
This is because of your multiple assignments of the elements. It actually thinks all four of your O and three of your H are different elements.
Are you sure? It is very unlikely that the species.out are exactly the same. Have you changed the pair_coeff command?
If fix reax/c/species and fix reax/c/bonds have the same nfreq and nevery and nrepeat are set to 1, then mol_fra.c will give you the same results as species.out.
mol_fra.c reads the output from fix reax/c/bonds. It reads the bond order cutoffs from Cutoff.dic.
Ray
Thanks Ray
1) Ok, it seems I took a mistake. Their (masked and unmasked) results are
different. Still, this means that I can't trust the species.out result when
I mask atoms... A bit sad, because this means I need to run all the
simulations again, or I need to use connection table and molfra.c. Is there
other way that I can use species.out normally with masked atoms system?
Of course you can use reax/c/species with masked atoms and still "trust"
the results. You just need to combine all repeated results into one via a
post processing tool. I believe you need some kind of text parsing tools
to analyze the species.out, you just need to combine them in your tool.
2) In the fix reax/c/bonds, you can only set Nevery, which was 400 in my
case. On the other hand, in reax/c/species, I used 1 1 400 for Nevery
Nrepeat Nfreq. I think the output frequency of both are same. Is this good
enough?
Yes.
3) Ok, that means molfra.c uses fixed bond order.... Connection table ( =
bond information by reax/c/bonds) also offers the list of bond order for
each atoms. Is there anyway that we can use this data to mofra,c?
You are confusing these two. Yes, mol_fra.c uses fixed bond order values
(defined in Cutoff.dic) to analyze and determine molecules and species -
these are user defined CUTOFFS, just like the cutoffs set in the
reax/c/species command. On the contrary, the bond order values from the
connection table (output from reax/c/bonds) are ReaxFF-calculated bond
orders between pairs of atoms and users do not control them.
Ray
2015-04-02 11:07 GMT-04:00 Ray Shan <[email protected]...>:
Thanks Ray
Yeah, my code is having a hard time to analyze repeating atom type in the
same frame.... (which is not considered in my code) I used gnuawk and other
unix command combinations. It seems I need to find different way to solve
this. Thanks.
enough?
Yes.
Sorry, my mistake. I confused about bond order and bond order cutoff. Now I
understand that the molfra,c use fixed cutoff only, not the fixed bond
orders. Thanks
