Hi Everybody
I would like to calculate the stress strain curve for Zirconium using lammps.I have used the following input script
log MM.defk.EAM.out
atom_style atomic
pair_style eam
read_data hcpl.in
pair_coeff * * Zrncs.eam
mass 1 91.224
regions of sample
neighbor 2.0 bin
neigh_modify every 1 delay 5 check yes
compute new all temp
compute pen all pe/atom
compute ken all ke/atom
timestep 0.0000001
thermo_style custom step temp press vol xlo xhi ylo yhi zlo zhi
thermo 250
thermo_modify lost warn norm yes
dump 1 all custom 1000 MM.defk.EAM.dump id type x y z
dump_modify 1 every 1000
velocity all create 1 585889 temp new
fix 1 all deform 1 x volume y volume z scale 10.1 units box
I am not sure how to take stress vs strain values .Could you please tell me how can I do it
Hi Everybody
log MM.defk.EAM.out
atom_style atomic
pair_style eam
read_data hcpl.in
mass 1 91.224
# regions of sample
neighbor 2.0 bin
timestep 0.0000001
thermo 250
how can I do it
have you checked the mailing list archives if somebody
has asked this or a related question before? you can start here:
http://lmgtfy.com/?q=stress+strain+site%3Alammps.sandia.gov
sjplimp
February 4, 2012, 1:19pm
#3
Strain is the box size/shape relative to what
it started at. Since you are deforming the box
explicitly via fix deform, you know that value
at any time. Stress is the pressure of the
system, or some component of the pressure
tensor, which compute pressure calculates.
So you know that at any time as well. It's up
to you to use those values to make a plot.
