Hi All,
I am trying to study Cu with Sutton Chen potential and am using LAMMPS.
From previous posts on Sutton-Chen on the lammps-user list, Dr.Plimpton had mentioned " EAM potential files that were created using the Sutton-Chen formalism". I was trying to implement that.
The terms of Sutton Chen potential was compared with the EAM potential(see image(2).jpg). To generate the data for the electron density, charge density and the embedding function for using pair_style eam & pair_coeff, i used :
density =power((a/r),m);
charge density = sqrt((1/(27.20.529))reijpower((a/r),n));
embedding function= (-1)ceij*sqrt§;
And this input data was used to run the code (attached- in.eam.txt). The data generated temperature & volume values quite large for Cu at room temperature. Any information on what i was doing wrong will really help.
Otherwise, please do let me know if there are other ways to implement Sutton Chen potential in LAMMPS.
V M
in.eam.txt (712 Bytes)
Cu_lmp_data.eam (12 KB)
