Syntax check of input script before simulation run
Now that I have a proper keyboard under my fingers and few more thoughts and explanations on this topic.
It is not that the usefulness of a “syntax” checker has not occurred to people before. The hurdles to get there are quite significant.
  • the LAMMPS input file language is not static like for some other codes where the file is parsed as a whole at the beginning. It is more like a bash script that is evaluated line by line.
  • on top of that you have the ability of loops and include files where you rewind the file (or open a different file) and start reading until you reach a marker and then continue from there. Now should you flag a syntax error on those skipped lines? it won’t cause an error when running LAMMPS for real
  • the next, and most major, hurdle is that parsing and syntax checking is done in each source file individually. so for a chance to have a meaningful and maintainable syntax checker, one would have to change this into having a generic argument parser class that reads arguments and allowed argument types from a descriptive string/table/struct. those descriptions could be “harvested” and processed for a syntax checker. however, that will also either incur some difficulties or require not backward compatible changes to the grammar, as currently some times the syntax changes based on keywords read first and you have positional arguments and required or optional keyword / value(s) tuples.
  • an alternative approach would be to write a “linter” tool that won’t recognize the entire syntax, but could handle some common mistakes, e.g. check on group/compute/fix/dump ids and general common syntax requirements as well as quoting rules etc. such a tool could also be educated about alternatives or print warnings when something is used that is rather ineffective (e.g. I often see people using many instances of compute reduce where a single one using multiple arguments would suffice and thus have much less negative parallel performance impact since each compute reduce requires a collective communication, same goes for global accesses of per-atom data and much more)
at any rate anything beyond the simple hack I suggested would cause a lot of work and would take away time from working on features that enhance LAMMPS’ capabilities to do exciting new research.
I tend to look at this from the “survival of the fittest” perspective: yes, losing time due to typos and avoidable errors is painful, but a) pain induces more effective learning b) smart people will eventually figure out ways to protect themselves from making such simple and avoidable errors and - most importantly - c) I take an untimely syntax error any time over a subtle error in the implementation or the physics of the model I am using. those are far more deceptive and “dangerous” and - in my opinion - are the cause for even more wasted resources (not to mention bogus publications that can lead to others making the same mistakes) in the end. when maintaining a software this is weighing heavily on one’s mind, since the simplest of typos can lead to bugs that can go decades without being detected.
