I’ve run into a peculiar problem; in a nutshell, I’m attempting to run an NPT simulation with rigid molecules, so I use the fix rigid/npt command. The command is:
fix 1 all rigid/npt molecule temp 300.0 300.0 100.0 iso 1.0 1.0 1000.0
At first, the simulation appears to be working normally, but after some time the box boundaries in the x direction diverge from the box boundaries in the y and z direction. The illustrative parts of the dump file are at the bottom of this email, along with the full input file. Since I used the “iso” keyword, I expected the box to stay a perfect cube, which it clearly is not doing.
This simulation was run using the July 2013 version of LAMMPS because it is the default on NERSC’s Hopper computer cluster. When I run the simulation on my local computer or on another cluster, on both of which I’ve installed the most recent version of LAMMPS (build serial), it works fine. This first led me to believe that the problem lay in the parallel usage of LAMMPS, so I attempted to re-run the simulation on NERSC with just 1 MPI task. However, the same error occurred.
I’m currently working on making a parallel build of the latest version of LAMMPS on NERSC to check that the problem stems from a bug that has been corrected since the July 2013 version. However, since I don’t see anything on the “Bug Fixes” or “History” portions of the LAMMPS website, I’m wondering whether this is the case…
I’d be grateful for any good pointers.
Efrem Braun
Graduate Research Assistant
University of California, Berkeley
Selected headers in the dump file follow:
ITEM: TIMESTEP
0
ITEM: NUMBER OF ATOMS
80
ITEM: BOX BOUNDS pp pp pp
0 100
0 100
0 100
…(skip ahead until right before the error first appears)
ITEM: TIMESTEP
12000
80
-8.34825 108.348
-8.34825 108.348
-8.34825 108.348
ITEM: TIMESTEP
13000
80
-8.79957 108.8
-8.79854 108.799
-8.79854 108.799
…(skip ahead to much later to see the error accumulation)
ITEM: TIMESTEP
100000
80
-845.976 945.976
31.9542 68.0458
31.9542 68.0458
The input file follows:
units real
atom_style full
pair_style hybrid lj/charmm/coul/long 9.0 15.0
kspace_style pppm 0.0001
pair_modify mix geometric
pair_coeff 1 1 lj/charmm/coul/long 0.0 1.000
pair_coeff 2 2 lj/charmm/coul/long 0.1553 3.166
pair_coeff 3 3 lj/charmm/coul/long 0.0210 1.580
pair_coeff 4 4 lj/charmm/coul/long 0.2071 3.748
read_data system.data #(I can send this if requested)
velocity all create 300.0 38564
timestep 1.0
thermo 100
group CofMs type 1
neigh_modify delay 0 every 1
dump 1 CofMs custom 1000 traj_npt_CofMs.dump id mol type x y z ix iy iz
run 100000
