table pair style
Dear lammps users,
I want to check if LJ table potential can reproduce analytic potential results, so I get table.txt by the following scripts:
Pair_style lj/cut 2.5
Pair_coeff * * 1.0 1.0 2.5
Pair_write 1 1 5000 r 0.5 2 table.txt LJ
But when I use this table potential via
Pair_style table linear 5000
Pair_coeff * * table.txt LJ
There is a warning massage:
WARNING: 1 of 5000 force values in table are inconsistent with -dE/dr.
Why is the force values inconsistent with -dE/dr? the outer cutoff(2 A) is less than lj cutoff(2.5 A).
Thank you in advance.
Best wishes.
Lily
Dear lammps users,
​because the test for -dE/dr fails at the minimum of the potential.
so the warning is to be expected. you should only worry, if there are more
than one points inconsistent.
axel.​
