tabulated long-range file generated by LAMMPS using reaxFF
Dear Lammps Users,
I want to use reaxFF force field in LAMMPS. Going through the LAMMPS manual and examples, I found out that LAMMPS makes it possible to tabulate the long-range interactions. To see how it works, I run the example provided for AuO system (you can see my input file in following). The problem is I am not able to interpret the information created by LAMMPS for tabulated interactions. I put also part of this information in following. I know that for each atom in the system it is computing certain properties but I just could not understand which properties have been computed here. I would be very thankful if someone could tell me that these columns refer to which quantities here.
#######################-------INPUT FILE---------------------------
units real
atom_style charge
read_data data.AuO
thermo_style custom step temp epair etotal press
thermo 100
pair_style reax/c lmp_control
pair_coeff * * ffield.reax.AuO O Au
neighbor 2 bin
neigh_modify every 10 delay 0 check no
fix 1 all nve
fix 2 all qeq/reax 1 0.0 10.0 1e-6 param.qeq
fix 3 all temp/berendsen 500.0 500.0 100.0
timestep 0.25
run 20000
#################################---------tabulated file generated by LAMMPS
step: 0
time_in_ps: 0.000
volume: 0.000
box_dimensions: 0.000, 0.000, 0.000
coordinate_angles: 90.000, 90.000, 90.000
temperature: 0.000
pressure: 0.000
total_energy: -72201.743
total_kinetic: 0.000
total_potential: -72201.743
bond_energy: -140400.477
atom_energy: 24217.086
lone_pair_energy: -0.000
valence_angle_energy: 20624.294
3-body_conjugation: 0.000
hydrogen_bond_energy: 0.000
torsion_angle_energy: 0.000
4-body_conjugation: 0.000
vdWaals_energy: 29509.751
electrostatics_energy: -24204.924
polarization_energy: 18052.528
chars_to_skip_section: 76800 ,960
1 0.779 3.901 0.453 31.075 40.446 13.900 0.550
2 0.779 3.901 4.454 70.511 13.877 -8.860 0.550
25 5.878 1.583 0.455 4.484 4.014 27.571 0.556
26 5.878 1.583 4.455 -24.462 52.401 -14.434 0.556
97 2.606 6.593 1.463 -8.363 20.908 21.748 0.554
98 2.606 6.593 5.463 4.584 -0.177 -3.436 0.554
217 5.884 6.962 2.451 -34.987 3.283 6.071 0.548
241 7.317 3.900 2.455 -37.622 -15.625 -3.499 0.553
289 2.613 1.210 3.451 7.638 23.248 5.099 0.547
313 4.050 4.275 3.457 11.745 22.812 18.706 0.552
385 2.406 5.022 0.268 27.193 -20.743 -60.935 -0.380
386 2.406 5.022 4.269 -25.952 -7.300 -12.399 -0.380
409 4.259 0.455 0.267 -41.678 -42.527 -13.677 -0.377
410 4.259 0.455 4.267 0.068 -75.615 22.202 -0.377
481 0.014 0.034 3.196 -14.659 -17.367 -15.511 -0.349
505 6.635 5.448 3.205 28.457 -3.205 -12.456 -0.347
529 0.979 2.328 3.259 -62.275 -38.761 -32.166 -0.381
553 5.675 3.154 3.268 12.508 -18.115 -13.730 -0.380
From LAMMPS doc page, using tabulation for long-range interactions is invoked by the keyword tabulate_long_range:
tabulate_long_range: To improve performance, long range interactions can optionally be tabulated (0 means no tabulation). Value of this variable denotes the size of the long range interaction table. The range from 0 to long range cutoff (defined in the ffield file) is divided into tabulate_long_range points. Then at the start of simulation, we fill in the entries of the long range interaction table by computing the energies and forces resulting from van der Waals and Coulomb interactions between every possible atom type pairs present in the input system. During the simulation we consult to the long range interaction table to estimate the energy and forces between a pair of atoms. Linear interpolation is used for estimation. (default value = 0)
With this keyword, ReaxFF automatically switches to tabulated long range.
Ray
