I tried to simulate alpha quartz with a special potential proposed in this paper http://www.sciencedirect.com/science/article/pii/S0022309315301253.
I linearly tabulated potential in two ways: Firstly, I use log scale of distance (from 10^i for i=-3 to 1 by 0.0004, giving 10001 data points); Also, I considered even space in the square of distance (r^2 from 0.000001 to 99.800001 by 0.01, giving 9981 data points). I used pair_write to see how well the interpolation but for distance less than 0.1, interpolations from both setting are very bad.
The potential table is created by Mathematica with a log scale distance.
Can I ask how to improve the interpolation in short range with large gradient?
Many thanks
Bingyu Cui
#Initialization############################################################
atom_style charge
Atom definition##########################################################
lattice custom 5.4047 &
a1 0.9092 0.0000 0.0000 &
a2 -0.4546 0.7873 0.0000 &
a3 0.0000 0.0000 1.0000 &
basis 0.4697 0.0000 0.0000 &
basis 0.0000 0.4697 0.6667 &
basis 0.5303 0.5303 0.3333 &
basis 0.4133 0.2672 0.1188 &
basis 0.2672 0.4133 0.5479 &
basis 0.7328 0.1461 0.7855 &
basis 0.5867 0.8539 0.2145 &
basis 0.8539 0.5867 0.4521 &
basis 0.1461 0.7328 0.8812
region simbox block 0 2 0 2 0 2 units lattice
create_box 2 simbox
create_atoms 1 box basis 1 1 basis 2 1 basis 3 1 basis 4 2 basis 5 2 basis 6 2 basis 7 2 basis 8 2 basis 9 2
mass 1 28.0855
mass 2 15.9994
group siliconatoms type 1
group oxygenatoms type 2
set group siliconatoms charge 2.4
set group oxygenatoms charge -1.2
Atoms interactions settings##################################
Si type 1, O type 2
pair_style table linear 10001
pair_coeff 1 1 potential.table SiSi
pair_coeff 1 2 potential.table SiO
pair_coeff 2 2 potential.table OO
pair_write 1 2 10001 r 0.001 10.0 table.txt Si_O 2.4 -1.2
pair_write 2 2 10001 r 0.001 10.0 table.txt O_O -1.2 -1.2
pair_write 1 1 10001 r 0.001 10.0 table.txt Si_Si 2.4 2.4
Equilibrate
fix 1 all npt temp 1986.15 5200.0 0.1 iso 1.0 1.0 1
thermo_style custom step temp pe etotal press pxx pyy pzz vol
thermo 10
dump 1 all atom 1000 dump1.qua
timestep 0.001
run 1000000
unfix 1
fix 1 all npt temp 5200.0 5200.0 0.1 iso 1.0 1.0 1
thermo 10
dump 2 all atom 1000 dump2.qua
timestep 0.001
run 10000
unfix 1
fix 1 all box/relax iso 0.0 vmax 0.001
thermo 10
dump 3 all atom 1000 dump3.qua
timestep 0.001
run 1000000
min_style cg
minimize 1e-25 1e-25 5000 10000
