Hello all,
In the manual section for temp/profile compute claims:
"After the spatially-averaged velocity field has been subtracted from
each atom, the temperature is calculated by the formula KE = (dim/2 N -
dim*Nx*Ny*Nz) k T, where KE = total kinetic energy of the group of atoms
(sum of 1/2 m v^2), dim = 2 or 3 = dimensionality of the simulation, N =
number of atoms in the group, k = Boltzmann constant, and T =
temperature. The dim*Nx*Ny*Nz term are degrees of freedom subtracted to
adjust for the removal of the center-of-mass velocity in each of
Nx*Ny*Nz bins, as discussed in the (Evans) paper."
But I think with N you mean number of atoms in a certain bin (bin style)
that belongs also to the group specified as group-ID. Is that correct?
If it's so, I think I should use the 'compute_modify comp_id dynamic
yes' if within my bins the number of atoms inside is fluctuating
although the number of atoms within the group is preserved. Is that
right?
P.S: Why the binning for temp/profile is limited in the sense of not
having the possibility of choosing the lower and upper bounds for a
certain coordinate ? I would expect the same capability as 'compute
bin/3d' for example. Would it be easy to implement modifying the
existing source code?
Many thanks,
Eduardo - (MSc student at Imperial College London)
yes, N = # of atoms in bin
you don’t need compute_modify dynanmic, b/c
the compute re-bins atoms every time it
calcs a temperature
Re: binning options. Compute temp/profile is
designed more for calculating a temperature
after subtracting out a local flow velocity. So
it can be used for a thermostat. You can limit
what atoms are involved in the calculation by
the group you define, which can also be a dynamic
group with a region limiting what atoms are in the
group.
If you want to tabulate the temperature in a bunch
of bins, see the compute chunk/atom and compute temp/chunk
and fix ave/chunk commands. That would be the
place to add an option limiting the spatial extent
covered by bins.
Dear Steve,
Thanks for your quick reply. The fact is that I want to calculate the
temperature profile of a sheared liquid in confinement that change in
width during equilibration (two mobile walls due to the barostating
process). Then when the fluctuations are minimal I shear the liquid
inside till steady state is achieved. At that point is when I want to
compute the temperature profile and it is observed that the liquid is
disposed in layers in which local equilibrium is attained. Because of
that, within each layer, it is possible to calculate the temperature
separating the peculiar and "non-peculiar" velocities in the flow
direction just how 'fix temp/profile' does. This command, as I commented
before, does not give me the flexibility I want on how to bin the fluid.
So two questions:
1) Would it be possible to implement the behabiour of this command using
'fix ave/chunk' for velocities and then manually calculate the
temperatures inside each bin from it?
2) Is there currently any way of doing not uniform binning in one
direction?. In example, binning from x_lo to x_hi with bins of size x1,
x2, x3, .. where x_lo - x_hi = x1 + x2 + x3 ... . That is because the
layers in my simulation might be of different thicknesses.
Regards,
