I am trying to get the phase diagram of a system of patchy colloids
using parallel
tempering. The dynamics of patchy colloids is integrated using the fix rigid,
rigid/nve or rigid/nvt commands. However, I am finding it difficult to impose
thermostatting for parallel tempering. Firstly, fix rigid/nvt gives an
error when
used together with temper. Secondly, fix temp rescale seems to not work
properly
because ( I think) it rescales only the translational temperatures. The
same appears
to be true for fix langevin. Can you suggest the kind of thermostatting
which should
work for my system?
Regards,
Chandana
