temper command
  When I use the temper command,I find the swap criteria may be wrong.Follow picture is my result when I use the temper command,
the A,B,C points which are not on the main line can not be explained.So,if I want to modify the swap criteria,besides modify the "temper.cpp",
should I modify other documents in the lammps.Thank you!
![Fe272-REM-120.png|420x291](upload://QcizI0MNwEtkUAVXl1wQ5o8NGU.png "Fe272-REM-120.png")
Thank you very much for your time!
With best wishes,
Qiang
You can modify anything you wish in temper.cpp.
If you find a bug with the swap criteria, then please post
the info to the mail list so we can fix it.
