Temperature fall to zero in gcmc
Dear lammps-users,
I used gcmc+nvt to simulate the methane (group methane) adsorption in clay slit using command, the clay (group illite) was kept rigid.
#keep illite slit rigid
neigh_modify delay 0 every 1 check yes exclude group illite illite
fix fixillite illite setforce 0.0 0.0 0.0
#initial minimize
minimize 1.0e-4 1.0e-6 100 1000
reset_timestep 0
methane md+gcmc
compute Tch4 methane temp
compute_modify Tch4 dynamic/dof yes
fix {pressure}methanenvt methane nvt temp {temp} {temp} 100.0 fix_modify {pressure}methanenvt dynamic/dof yes temp Tch4
fix sorption methane gcmc {Nfreq} {Nexchange} {Nmove} 12 9999999 {temp} {mu} {disp} pressure {pressatom} & fugacity_coeff {fugacity_coeff} charge 0 group methane grouptype 12 methane tfac_insert 2
I got a unreasonable result, the temperature fall to zero and the potential energy becomes very high when the number of methane in system was zero, even some other methane were inserted in system. The output was attached. Anyone has suggestions? How to fix it?
Best regard.
Dongbo Wang
1.out (45 KB)
