Temperature going to zero despite using Langevin Thermostat
Dear all
I am trying to simulate the behavior of mono disperse hard spheres in an insulating medium for my class project. I am using FLD. Inspite of using Langevin thermostat the temperature goes down to zero from a starting of 300 K. I am reproducing the script below.
Regards
Anurag
Here is the script
Big colloid particles and small LJ particles
units lj
atom_style sphere
lattice fcc 0.005
region box block 0 4 0 4 -2 2
create_box 1 box
create_atoms 1 box
set group all type/fraction 1 1 23984
set type 1 diameter 20
velocity all create 300 4928459 dist gaussian
multi neighbor and comm for efficiency
neighbor 1 multi
neigh_modify delay 0
comm_modify vel yes
pair_style lubricateU 1.0 0 10 10.6 0.01
pair_coeff * *
timestep 0.00001
fix 1 all langevin 300 300 20000 48279 omega yes
fix 2 all nve
thermo_style custom step temp epair etotal press vol
thermo 1000
dump 1 all atom 500 dump.colloid
run 100000
You are using LJ units and setting the langevin thermostat
to 300 - does not make sense. You only have 1 type
of particle, so do not use atom_style sphere. Just
set sigma = 1, as there is only one length scale in
your model.
