This is my input file:
---------- Initialize Simulation ---------------------
atom_style atomic
boundary s s s
atom_modify map array
timestep 1e-3
---------- Simulation Box -----------------------------
read_data data.DAT
---------- Define Interatomic Potential --------------
pair_style airebo 3.0 1 1
pair_coeff * * CH.airebo C H
---------- Define Settings ----------------------------
#Initial velocities------------------------------------------------
velocity all create 300 511124 rot yes mom yes
Relaxing the Imported structure in the desired temperature------------------
fix relax all nvt temp 300 300 0.01
compute mystress middle_atoms stress/atom myTemp
compute reducedstress middle_atoms reduce sum c_mystress[3]
thermo_style custom c_reducedstress
thermo 1000
dump relax_position all atom 5000 dump2.atom #For having video!
run 5000
undump relax_position
unfix relax
Zeroing Stress----------------------------------------------------
thermo_style custom fmax fnorm
min_style cg
minimize 0 0 1000 1000000
Defining fixes-------------------------------------------------------
variable stepnum equal 1000
variable Nstep loop ${stepnum}
variable disp_upper_atoms equal 0.01*v_Nstep
fix fixing_Left_side lower_atoms setforce 0 0 0
fix fixing_Right_side upper_atoms setforce 0 0 0
label looplable
displace_atoms upper_atoms move 0 0 -0.01
fix fix1 middle_atoms nvt temp 300 300 0.01
thermo 5000
thermo_style custom step temp pe v_sigma
run 5000
next Nstep
jump in.CNT looplable
Is it true to change my input file to:
velocity all create 300 511124 rot yes mom yes =====> velocity all create 600 511124 rot yes mom yes
fix relax all nvt temp 300 300 0.01 ======> fix relax all nvt temp 600 600 0.01
label looplable
fix fix1 middle_atoms nvt temp 300 300 0.01 ======> fix fix1 middle_atoms nvt temp 600 600 0.01
thermo 5000
run 5000
next Nstep
in order to simulate my functional CNT in the thermal environment? (600K is the temperature of the environment. Indeed, I want to simulate the functional CNT in thermal environment)
I hope I can explain my purpose truly.
Thanks.
